Ok. What charger do you have for the bigger battery?
Is it a smart charger with adjustments?
Those are the same types of packs I used.
I just plugged mine in and adjusted a setting, pressed charge.
Not much help here I'm afraid.
My charger and batteries are 10 years old now!
Do you own other r/c's?
What types of batteries are they running?
What other batteries are you charging?
I'm thinking a good, flexible battery charger might solve a few problems at once in this case.
Again, for this case I'd like to refer you to the smartest R/C battery guy on the site.
@Greywolf74
The best charger for lipo is the Hota 6
I am pretty sure it will handle your nicads also but I do not own one (yet) and am not sure 100%.
I am also not sure if there is a lower cost unit that will serve your needs if you ONLY charge Nicads.
Dealing with the battery power is #1.
2nd comes leds and other things to plug in.
