well i got a new MGT 4.6 and done my break-in today. The weather was in the upper 40's so it was pretty chilly out still..i followed a guide i found on the web and think all went well..1st tank 1/4 throttle (factory needle settings, rich rich rich) get temp up to 190-200 (i had to put a paper towel around the head to get the temp up since it was so cold out.) then let it sit at BDC for 15 minutes..2nd tank the same except go 2-3 seconds at 1/2 throttle and get temp up around 190-200 again..3rd tank, turn High speed jet 1/8 turn clockwise to lean and run 3/4 throttle and get temp up to 200-215..4th tank, 1/8 turn again on HSN, short bursts at full throttle get temp 205-220. truck sat with piston at BDC for 10-15 minutes between every tank..
My question is, am i now ready to try to "tune" the motor? I have not touched the Low speed or the idle screw. They are set at factory settings and the High speed needle is 1/4 to a 1/2 turn leaner than the factory settings. I am getting smoke and it is using the fuel FAST so i assume i am stll very rich..lots of oil on the rear A's and dripping from the exhaust..truck seems to "load" up in the low to mid speed range..My guide stopped after the last tank so i guess i need to know what you guys would do next...This thing is great...who would have thought that a 33 year old guy could have sooo much fun with a new toy
any and all responses appreciated..
Chad
Chad
