Ok, so I have the OFNA Picco RTR and for the first tank of fuel I ran it at around 4.5 turns out. Kinda rich, nice amount of smoke and extra fuel/oil from the exhaust. It probably took close to 30 mins to run at idle with 1/4 throttle here and there. After running I cleaned her up and dropped a couple of drops of after run oil on the pistion and cycled the engine a few times.
Anyway, I tried to start her up yesterday and here is what happened. I primed the engine to the point that fuel was entering the carb. I tried to start the engine and it would not turn over. I checked the batteries in the igniter and they were fine. I thought it might have been flooded so I took out the glow plug and yanked the pull start a few times but nothing. The glow plug seemed wet, but it might have been a figment of my imagination. I tested the glow plug and it glowed bright red. Put the glow plug back in and it still would not start. I finally replaced the glow plug and after 3 or 4 times of trying to start her she finally turned over. She ran fine for two tanks.
My question is, do you think the glow plug was bad or did I just not prime it enough?
I'm guessing it just wasn't primed enough. I've read that flooded engines act like seized engines...is that true?
Another question: Do I need to put after run oil in after every run? Or only if I'm not going to run it for a few days?
