So I've had this 1/8th nitro sitting assembled for some time and finally got around to starting the break-in process for my Dynamite Mach 2 .21 engine using the heat cycle method. Had the engine running pretty good. Even ran some figure 8's in the street for aminute. Not fast mind you...but not super slow. Anyways, now when I attempt to start the engine it will only start if the carb slide is opened a bit and will not hold an idle, have to use throttle to keep it running. At this point I've reset to factory setting and still have the same issues. Carb gap is very close to 1mm and always has been. So in my mind, understanding how a carb works (fuel air mixer) I'm thinking I'm running rich and may need to increase the carb gap a touch. I did also notice upon blipping the throttle some fuel was spitting out of the exhaust. So I need to lean it out and really my only question is whether to start with the LSN or HSN? In so far as achieving a solid idle. I've done A LOT of reading, found the flow chart, thinking maybe some of you have experience with these engines and maybe can point me right to some good setting for break-in. The factory setting aren't working. Could be the carb slide gap but everything I've read states 1mm for just about every engine. Thoughts? Appreciate any help.
Also. I'm gonna take the engine apart tonight and clean it good with some carb cleaner, oil it up and seal everything with some
RTV. No leaks but something that
needs to be done.
needs to be done.
