new rustler
jimmy 1234
started break in it goes wide open by itself. had nitro years ago just trying it again thanks
check the basics. fuel lines air leak?.servo(is trim set wrong) carb setting write the b4 down.
its new out of the box less than 15 min run time. should i just send it back?
With any Knew RTR buyer should inspect everything and make adjustments where needed. They are never RTR.
Was the carburetor still mostly close when that happened? Was it happened near the end of the tank of fuel? Any bubbles in the fuel lines? It will be great to provide a video.
Also make sure the starter plate is still secure. Sometimes screws do come loose and cause problems.
yes carb is closed
make sure to use new batteries set fail safe correct to brake if low battery or signal loss.
sprayed brake clean around looking for air leak. none found adj low speed no diference at all
you won't find a air leak until you get the motor running. That's not going to fix your problem????? Start over and set the carb back to factory needle settings and read the radio manual on how to set the fail safe. I bet that was the real problem? Low batteries and fail safe set up wrong.
thanks to everone who helped adj low speed all is well thanks
J
Replies
3
Jaydiaz1993
J
yfzracer450
Replies
5
easy rider
E
J
Replies
11
1K
johnnydmd
johnnydmd
M
Replies
mercjr
M
