test runs this afternoon........lil help please
Speaking of breaking her in...........I've read elsewhere that it really takes over a gallon to get good and broke in and I just finished putting tank #10 thru her today......while doing so, I did an experiment..........2 actually,
First was a solid high speed run with no body on and checked the temp.....got 197......put the body on and repeated the run......temp this time was 270. Now if I read elsewhere correctly, 270 is NOT a good thing, is that right? Should there be that much temp difference with and without the body? Maybe I should cut out the windshield for more airflow?
Second was, I read somewhere that if the shift adj. screw was turned all the way in then the tranny would be locked in first, if this is correct thats what I did and noticed performance was as it has been all along, leaving me to believe that all this time it has never shifted and been running in first this whole time and not second as someone elswhere had suggested. I then turned the screw out 1 full turn and again no shifting. At this point I am not to concerned cause everyone says this will change the more it gets run and leaned out......but with the above temp. readings I wonder if I really dare lean it out much more. I'm still getting blue smoke so I'm not worried about it running TO lean, but if it needs more RPM's to actually get to shifting, I wonder what really is a good running temp for high speed grassy runs in a baseball field, with a couple donuts around the infield thrown in, cause they will only continue to go up if I lean it out more.
So I should return the shift adj. screw back to factory settings and just chill for now as far as the shifting issue is concerned?
