stunt
I picked up a brand new lst2 last Saturday. I went easy on it for the first 2 tank fulls (lots of cool down breaks after each 2-3 minutes of running). I leaned it out a bit more after each run, and it seemed to pick up a bit more power each time.
Up until this point, it would start up pretty much right away hot or cold. I have now run perhaps 4 tanks through it and now I can't get the rpms up high enough to shift into 2nd gear, even in low range. It also won't start when hot.
So I went back to the initial settings (high idle out 4 turns and low idle out 2 turns). It still won't get enough rpms to shift into 2nd and it still won't start when hot. Right now the high idle screw is perhaps 3.5 turns out and I get very little smoke (as if it is running real lean) when I get on it, either from a standstill or when accelerating. Going back to 4 turns out doesn't make a bit of difference.
I picked up an infrared temp sensor and its running at about 270 or so. Mind you this is with no body on it (max airflow), and without it even getting into 2nd gear in the low range.
When it ran the strongest it wouldn't pop the front wheels off the ground on asphalt even in the low range when flooring it from a standstill or when already at speed.
I'm in Virginia and it has been hot and humid as hell all week with temps around 100 degrees. Could that have something to do with it?
Should I just be patient with it and continue running through tanks with the high idle at 4 turns and low idle at 2 turns until I burn all the way through my 1st gallon?
I guess I'm curious how long it takes to brake in one of these things. My buddy picked up a revo 3.3 at the same time I picked up my lst2 and he is running circles around me. Both engines were broken in in the same manner (we ran them both side by side) and they both have had the same amount of fuel run through them.
Will the Mach 427 begin delivering the goods after I run some more fuel through it, or should I bust out a LRP z.28R spec3 if I want to do wheelies and be able to keep up with my buddy's revo 3.3?
