No-no...you can get it. Let's try this another way....as perhaps I'm not articulating correctly or....but want to help. Below is a succinct version of how I tune. As noted, I am still learning (and sure I will for many years to come). Definitely follow NitroJedi's advice...I KNOW he knows what he's doing (to the point it's almost scary). I don't know Bobahloo, but he seems very savvy at tuning as well...so definitely welcome both their feedback below. If I am off on one, two, or ALL items below they can chime in again. If I'm wrong on everything I'll wonder how they hell I got my engines to run the way they do...but hey, I always look to improve....and hope to help as well what I am learning--instead of being an internet critic. ;-)
My hope is this will at least get your started in the right direction:
1. I put the needles back to stock (or at least close enough to where it's rich but keep the vehicle running). This includes idle-stop, which is usually 1-1.5mm.
2. I start the engine....then after about 15-20 seconds pinch the fuel line near the inlet to get an idea how off my LSN is. Looking for smooth RPM increase and for it to stall around 7 seconds. This is not me tuning the LSN...but just getting in the ball-park.
2. I run the vehicle on the terrain I'm going to run until it's heat-saturated. They all differ, but my Nova's and OS 25xz seem to take at least two tanks. Thus I would not tune on pavement then run it on a track.
3. I tune the HSN first. I'm simply wanting to get in the RPM range where I'm comfortable.
4. I run it more, and listen to the what happens after WOT (when I let off the throttle). If the RPMs carry on...I richen my HSN a bit.
5. At this point my engine idle is almost always two-staging and idle is high...but that is okay. I do another hard pass and then let it sit and listen to the idle. Normally the idle will be high, then will drop after a few seconds..or when i blip the throttle.
6. I lean the LSN about 1/16 of a turn, and repeat #5 above. Typically the idle will be high, then drop after say 10 seconds. I continue this process ensuring that the time it takes for the idle to drop is increased. So normally at around the 20 second mark I'm good.
7. So at this point I have a engine that has good RPMs and after WOT does not run on, and the idle stays high for about 20 seconds.
8. Then I lay down my idle. I don't measure it...but it's normally around .7-.8mm.
9. I run it again...if, after WOT the idle rises....I'm usually too lean on bottom so adjust and then . As I've stated many, many times...it's about the idle-stop/LSN. There are times I'll need to revisit the HSN as well.
10. Once I have a crisp take off (no big puffs of smoke) I begin to listen to my clutch. By that, depending on my traction and clutch setting....I might need to spring up or down. For example, if, when I take off and I lag (the RPMs increase but remain static OR I am breaking traction)...then I spring down. Just like with the idle, you can listen to your engine to help determine the torque delivery for your clutch setup
This is my basic tune. It sounds easy, but there are a slew of variables and it's taken me a long time (longer than most people I imagine) to become consistent with this.
I am not saying this is the RIGHT method...just what I do. As noted I welcome feedback if I am going in the right direction or mis-informing myself. My intent is to help give you a general understanding.
Thx
