Hello i have a New Bright Snake Bite Monster Truck and I am looking for some information about how to repair it. The company does not sell replacement parts. All four wheels stopped turning. First the two driver side (front and back) at the same time and then the two passenger side (front and back) at same time. I checked each motor separately after disconnecting them from the circuit board. All four motors worked during test. Then I checked the voltage to the connections as I moved the controller arms (circuit board turned on). I was able to get above 13 volts at each connection with wires off. I cleaned the terminals with electric cleaner, even though the terminals looked good. As I started connecting each wire back to the circuit board one at a time, I notice that I could not get the wheels moving again. It appears that once you add a load back on to it it shuts off the current. There are four connections , one for each tire. Does anyone know what may be going on and how to fix it? Thanks
