need help
josh1
I've had my revo just a little while,I'm not at any kind of pro.but i know a little about how things run and i think I'm haveing clutch or transmission problems.I've noticed it lately reving up a lot more and no power behind it,and now it want even roll in the grass,all it does is idle up.ne help would be appreciated:\
Runaway Jim
RCNT Talkaholic
Providence
Bashing
if it will rev but it won't move much, if at all, the first thing you may want to check is the inside of your clutch bell. you may have broken the spring or worn down the shoes to the point where they need to be replaced. Take the engine out of your truck to get at the clutch bell. remove the c-clamp, or whatever you call that piece holding the bell on the shaft and slide the bell off. Hopefully it will be obvious as to if it's a problem with the clutch shoes or springs. A replacement may be in order.
josh1
thanks bro
are there any kind of step by step guids on how to remove engines and components out there?
rckid91
Hardcore RCNT User
Bashing
Looking down from the top of the cooling head remove the 4 screws in the engine mount.
cut the zip tie on the coupler that holds the header to the exhaust stinger.
Then remove the screw on the engine mount where the throttle linkage pivots and remove engine
cheeseball01
RCNT Qualifier
San Antonio
Racing
Well, clutch issues are possible, but this sounds more like a stripped spur gear, or an extremely loose slipper clutch. Make sure your spur gear is good and if it is, try tightening the slipper and see if it helps before going through the trouble of removing the engine. When the clutch has issues it's usually the other way around, the wheels want to go even when they shouldn't. It's usually very hard to start when there are clutch issues as well. How's your mesh between your CB and your SG? Do you bash with this Revo? It's possible you could have bumped the motor mount bolts loose a bit and your mesh is gone. LMK if you need additional info/help.
josh1
I've got the motor off now,and the clutch looks fine to me ,i dont know exactly what imlooking for thought
cheeseball01
RCNT Qualifier
San Antonio
Racing
Yeah, based on what your problem was, the clutch is probably fine. The gear that is on the back of your transmission (The spur gear) How do the teeth look on it? How far out on the shaft is the nut that holds the spur gear on?
cheeseball01
RCNT Qualifier
San Antonio
Racing
there's your problem. Tighten that bad boy up for a bit until around an 1/8th inch of thread shows, then give it another whirl. There's a hole in the end of the shaft that comes out the other side of the Tranny, stick a small screw drive in there to hold the slipper assembly in place while you tighten the 8mm nut. Make sure when you put your motor back in, you check your mesh between the SG and the CB. You can adjust this with the two long bolts on the each side of the motor mount. Crack the back one and then the front. Make your adjustment with the front and then tighten the front back down, then tighten the back down. (Note, front and back are based on you looking at the car from the side with the motor closest to you).
Give me a holler if you need more help.
Cheers,
Curt
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Thread starter Similar threads Forum Replies Date
Connor_TK.Extra Need help choosing car Electric RC 12
jlobbia Need help finding a pull start for the sc10gt Nitro RC 1
jlobbia Need help identifying associated nitro short course truck Nitro RC 3
T I’m new to rc cars and need help Nitro RC 7
CameronCodes BROKEN SERVO!!! IN NEED OF HELP!!! Electronics 12
Simonh080 Need help with my hyper 7 nitro Nitro RC 19
hoopdoggy I need help with my nitro HPI rs4 mt Stadium Trucks 30
N Need help finding battery Electric RC 11
Z Need help identifying this nitro engine! Engines 10
Connor_TK.Extra Need help with parts for my nitro HSP bug crush RC car Nitro RC 15
Connor_TK.Extra Need help with shredded cluch bell Nitro RC 12
W Dug out my old Nitro buggy, need help, it's been so long! Nitro RC 1
RookieNumberss Need help identifying what appears to be a bottom of a shock Suspension 5
T Need help ? Buggy and Truggy 4
J Help. Need HPI motor mount 86000. Nitro RC 0
N Need help identifying this nitro car Nitro RC 5
8 Need help identifying this touring car.. On-road and Rally Cars 7
C New here need a little help identifying Electric RC 1
Spencerman74 Need help identifying these planes and how much their worth. Nitro RC 2
E Need help with a Kyosho GS11X Engines 4
F New and need help deciding. Electric RC 4
C Need some help finding a Tx for an old Golden Arrow Electronics 5
M Need help with my wheels Electric RC 2
M Need help with wheel Electric RC 1
H Need help identifying engine Nitro RC 0
M Need help with my pinion and spur gears Electric RC 3
Kimmie28 Need help Paint & Body 3
J Need help with buying parts for my buggy (1/8) Electric RC 5
SpikeTop I need help with tires 1:8 scale Wheels & Tires 17
4 i need help Electric RC 1
C Hello in need of some help nitro rc upgrade Nitro RC 38
Kimmie28 Need help identifying these. Nitro RC 21
F Hey guys new to the world i have a savage x 4.6 just need help to make sure I'm doing things correctly Nitro RC 7
Aden Richard i need help with my brand new lightining str Nitro RC 13
Snowman110011 Need Help With WLToys 12429 RC Rock Crawlers 1
Freddy i need help with placement of a Dbox2 on a Rovan Baja1/5 Buggy. Large Scale RC 0
Freddy Need help to find rc stores in Spain RC Shops, Events, & RC Tracks 1
S Need help identifying a gas boat and motor. RC Boats 6
T Need help identifying this RC truggy Buggy and Truggy 1
D Need Help Nitro Buggy Nitro RC 11
S Need help on setting carb please Large Scale RC 4
Brody hawk I need help with my tmaxx 3.3 Nitro RC 9
P Need some help identifying this model please Nitro RC 3
E Need help adjusting exhaust wire Nitro RC 0
E Need help gearing Arrma Typhon 3s Buggy and Truggy 4
E Need Losi Mach 427 parts and help please. Nitro RC 8
D Need help tuning my OS 18 cvr i saw the tuning fourm already but i need a bit more details Nitro RC 3
M Need help with Redcat XTE 1/10 Electric RC 15
D Need help tuning my O.S. MAX. 18 CV-R. Engines 7
S Need some help with identification of this car Team Losi LST 3
