Need a good set of 95-100mm rear drag shocks
WickedFog
Community Leader
Build Thread Contributor RC Showcase: 9
Terre Haute, IN
  2. Crawling
  3. Scale Builder
I got the shocks on the Slash build all rebuilt and working smoothly, but I'd kinda like to grab a set of shocks that will work better on the rear of the car. The stock shocks are 102mm, but I have added 6mm limiters inside the shocks to lower the rear a tad, then also added some 6mm limiters on the outside to keep them from burying the tires into the body. So actually, 95mm would probably be best.
I have looked at the Pro-Line Powerstroke 102mm and Pro Spec 100mm shocks, but not sure which would be best. I would still need to limit the stroke on them. I also see the Custom Works ones, but they don't give a length.
Any suggestions?
Thanks!
I wish I could help. I have a DR10 with the stock shocks. I put 80 weight in the rear and 30 in the front. All four shocks are 95mm long.
They sell the full set for $32.00 on EBay
https://www.ebay.com/itm/Team-Assoc...=p2349624.m2548.l6249&mkrid=711-127632-2357-0
They seem OK but I have not driven the car so I don’t know.
I would rather have threaded collars to adjust the springs
Those little jems are $63.00 for two shocks.
https://www.ebay.com/itm/TEAM-ASSOC...=p2349624.m2548.l6249&mkrid=711-127632-2357-0
Looks like the threaded ones come with different spring collars to adjust length.
