my tmaxx 3.3 is overheating??
jaketmaxx3.3
I'm new to the nitro trucks and i have a 4909 tmaxx 3.3 . i run it for fivr minutes and it heats up like crazy... why would it be heating up so much.???
prbly running too lean turn the high and low speed needles out at least one turn or put it back to factory settings
If you randomly turn both needles a full turn, you'll have an engine that will not even start.
Determine where the problem is, AFTER the engine is properly warmed up. While running WOT are you getting a good trail of blue smoke? If not, richen the HSN by no more than 1/8 of a turn.
If you are getting ripping good peel outs from a dead stop, it could very well be the LSN that needs to be richened, 1/16 turn at a time, and with either needle, do a few good passes to test it before adjusting any more. You'll soon see what improves, and you'll know when you have it right.
