My mini e revo only receives a small power boost between 2s and 3s!
ksbs
I wanted more power from my mini e revo so I went from a 2200 mah 2s 35c to a 3s 1300 25c, but recieved very little power boost, is this normal?
Yes it is if you haven't changed the pinion. I had two pinions that came with mine. Even the one with the lower tooth count was a bit too high for mine on 3s and caused it too overheat. YMMV
ok, I do get wobble in the rear and it clicks, even when shimmed
for some reason the smaller pinion keeps coming loose
idk why
idk why
The pinion grub screw needs a bit of thread lock on it my experience. My go to for this is the blue Loc-Tite 242 stick.
It does stay on now, but then the motor comes loose....
