I have a Mayhem with the .26 engine in it. I think it has about 3 gallones through it or so. The engine starts up fine, tunes well, runs greats, and idles well. After about 5 minutes of running the buggy around, I notice that the idle has changed when I bring it in to temp check it. In fact the idle will get so low that the engine will just die? What's happening?? First the idle is good; I run it around and bring it in then the idle is slow enough to stall the engine so I need to adjust the idle at the transmitter.
Also, even after adjusting the idle at the transmitter, the engine seems to load up anyway and dies after 10 secs or so?
Anybody see this behaviour in their .25 sportwerks motor; any ideas how to make the idle more reliable.
