motor
king_woody
what would be the best brushless motor the e revo because i want alot of power
I agree 6S is too much. I run 6S in my Savage Flux only when doing stupid tricks. Hey Dom I was looking at your link and just noticed the "Sway Bar" set-up. That is pretty trick too!
like i was thinking about getting the Feigao 580L Brushless Motor but i dont know if they are any good and i know that the mamba monster is good tho and i was also thinking about trying the Castle Creations Mamba Extreme 34V - Leopard 5692 1090KV Motor from kershaw designs but i think that would be way to much power for the truck
Both would be MAJOR overkill. You are going to have a hard time keeping the drivetrain together on that. A standard 1/8 scale set-up will be MAJOR power like you are looking for. Trust me on this. The set-up in the Savage Flux HP is almost un-drivable on 6s and that is in a truck about 3-4 lbs heavier than the Revo.
yea thats the down fall becasue i knew someone with the mamba monster in the revo and he could not keep the front end down and i dont want to pull wheels that fast so i dont know what to do on how to keep the front end down the only thing that i can think of is put all aluminum parts in the front end and thanks i think i will just get the mamba monster and just play it safe right now
and how would i even put the motor on can i use the motor mount thats on it right now or do i have to get a single one to put that motor on the revo
The motor will bolt up to the stock mount. A spacer may be required. The single motor mount is a much cleaner look though. The Mamba Monster is fully programmable, so you can tune it to calm down takeoffs. A lighter trigger finger will be your friend as well.
A center diff also helps keep the front wheels on the ground. I had the same wheelie problem with my 1/16 Revo VXL on 3s and the center diff cured it.
You bet man...like said above the throttle cure is ultra programmable on the MM ESC and you can do anything you want with it. That is what I love about Castle Creations.
The computer interface is simple enough for even me to use. Just like a nitro, small changes, one at a time, with some testing in between so you see if you like or dislike the change.
does the Castle Creations Quick Field Programmer Car even work that good or is their a point to get it even
The field programmer is able to be used in a more mobile setting than the Castle Link programmer as well as being connected to a computer like the Castle Link.
I haven't used one, yet, so I don't really have advice on the FPC. I have used the Castle Link and love it.
