Deans Ultra plugs are not the absolute best but for the ease of installation and price they are probably the most practical choice.
From minis to larger electric they do a great job.I purchased so far about twenty packs of male/female connectors and did ALL my electrics using the Deans Ultra.
You simply cut off the cheapie Tamyia conectors on the ESC,motor and cells(becareful not to cut both at the same time,SHORT ! ).Strip the wire about 3 to 4mm,prime with solder.Do not let the wire absorb too much solder or it will remain stiff(you want a flexible wire).Just make sure the striped wire has solder on it.
Next you prime each connector on the Deans Ultra plugs,make sure you are using a quality iron and a HOT iron(45W or more) .Each connector should take around a second to prime well(if its longer practice soldering skills on some junk wires before).
Slide a short piece of shrink tube on the now cool cableabout 3 inches or more from the soldering point.Solder the deans primed connector with the primed wire...heat up the wire tip and both fuse as one.Just after the joint is made,slide quickly the shrink tube on the joint...the tube will shrink on the still hot joint.
And as always respect polarity.
Easy,soldering is very easy.Just remember a HOT iron,a third hand or vise to hold pieces while soldering.Some practice on junk wires and common sense(never overheat parts).And you are good to go
Note
Most racing ESC's have soldering tabs,primed with solder or gold plated tabs.Same principle,a hot iron and quality solder make soldering easy,and use flexible wire.I use Deans Wet Noodle 12GA wires all around(save for micro cars).Always always prime the wire end to be soldered on to the tab.The joint should take no longer than a second.
