Breakin day problems...
First off.. the truck was faster than i thought. Man it was a lot of fun to drive.
First problem.. mine kept cutting off with braking. I leaned out the idle speed screw.. problem solved.
Second problem.. my roommates truck was running great and i accidently hit his back tire and broke the hub carrier.. dangit... There isn't a LHS nearby that carries mgt stuff, so i was wondering if one of my tmaxx hub carriers would work. I know it will not be as durable, but I was wondering if it would run on it for now. I do think the hobby shop has the rpm ones for the tmaxx, and I did read that those would work on the MGT. So i might pick up a couple of those for now.
Third problem..
the shaft start cup that sticks out of the back of the motor is gone. I don't know whrere it is or how it happened, but it is gone. WTF??? has this ever happened to any of you?? there is a rod about a 1/2 inch log sticking out of the back of the motor. is that right??
Fourth problem.. I think some guy got sick of hearing the trucks run and power mike'd a really powerful cb.. because my tmaxx and mgt when crazy and stuck out at WOT.
the mgt turned over (thank god) and the tires ballooned out. So my motor was running wide open for about 30 secs.. do you guys think this is going to be a problem??
thanks,
adrian
Third problem..
thanks,
adrian
