Tmaxx96
Gone - bye bye.
My bros mgt Driven thant BROKEN as always
yah mee too I'm doing it to my tmaxx or savage after i get it the only thing that breaks on this truck are those balls thow do you guys know of a better set?
They make those pivot balls in titanium and unobtainium too.....I have the titanium ones.....Wheres the front shock spring? You can fix that body crack with self stick foil tape as a backer and med tire glue in the crack to rejoin it..Good Luck
Say wha? You mean the Pro-Line [SIZE=-1]by-pass shocks[/SIZE] you have in the front? A shock IS an ABSORBER there guru keep focused! It is called a shock absorber......so yes you have them on all four corners; I would hope. However knowing you...I am not so sure. But the Pro-Line by-pass shocks do not have springs you are correct.the front shock is an absorber there is only 1 shock with a spring al the way around on each arm.
Its in reference to the fact I thought he was missing a spring in his suspension setup until I saw a few racing T-Maxxes and they look the same with the shock and damper design....
