You could try that ,but what I found on them ,is the retainer that holds the needle bearings in
the o-way bearing is very fragile an they tend to crack so it is possible that it is ,so you might
better start looking for a new one!
They are snapped in with a c-clip ,I am not sure ,but I think someone else here said that the shaft
was bigger from the 4.6 version ,but to make sure ,you can check ,if they are the same size ,you can
try swapping out the o-way bearing with a 4.6 one!
I thought that the only change internally on them was the spur output shaft & metal gears ,an
the main shaft was the same size!..
