MCD Racing W5 FT short course truck
WoodiE
Kind of good admin
Administrator
Lexington, KY
MCD Racing has a new short course truck, the W5 MAX which offers an extended wheel base, wider track width, a new body, reinforced rear alloy stiffeners as well as new allow shock towers.
MCD Racing W5 FT Features
  • Top of the line competition off-road Short Course Truck
  • Easy assembly/dis-assembly
  • Easy maintenance
  • Centralized and compacted parts layout on chassis
  • Elite racing design ultra-durable high performance parts
  • Fifth generation MCD chassis & suspension arms
  • Sophisticated full-time 4WD Shaft Driven mechanics
  • Ultra strengthened chrome drive shaft and axle
  • Easy gear mesh system
  • Easily removable one-piece electronics tray
  • CNC machined, anodized light-weight 7075 T6 aircraft alloy chassis
  • Strengthened long wishbones
  • Solid and durable side guards
  • Easily removable composite front, rear and center diff houses
  • Ultra durable front and rear adjustable brake system
  • Rear-brake only servo slot
  • 5mm light-weight 7075 air craft alloy front and rear towers
  • Optimized multiple shock mounting holes
  • Coil-over extended alloy shock absorbers with High Pressurized Cell™ System
  • Ultra hardened steel transmission gears
  • Double ball bearing anti-roll bars
  • No-Stress-Effect polyamide front and rear bumper
  • Ultra durable steel ball cup-joints
  • Super-Cooling V5 air ventilation system
  • Viper Racing Air Filters with dual layer foam and thermoplastic hose
  • Barracuda G performance exhaust (Optional)
  • Adjustable CG
  • Adjustable weight distribution
  • Molded fuel tank with shake absorbing separators
  • Front/rear/central 90˚ ramp self locking diffs
  • Ultra rigid roll cage
  • Fully composite body accessories
  • Drive and shock shaft boot
Check out more info about the W5 MAX at MCD's website here.
