Magnet came Detach from the Can
thetmaxxman2016
RCTalk Qualifier
taylor
The Magnet came Detach from the Can on my 9T Speed gem when I was jumping.:opps: What should I use to Attach the magnet back to the can?
I think they are set in a specific way....might want to be sure before you slap it in and can't get it out....
Some epoxy will do just fine. Just use a REAL thin coat of it. There are some little V or U shaped spacers that go between the magnets. Make sure those are in place. Then let the magnet set up all night, and you should be set.
A strong epoxy,make sure the magnet is in place and secure it.24-48hours cure time and it should not budge.
Jumping is a motor killer,as magnets may crack.If the magnet is in one piece and you epoxy glue it to the can(like was said before a nice even thin coat)it will remain there.
...unless you suffer a fatal and unlucky crash.
