One way diffs
Plaid,
I agree, in the real world of RC on road racing we run a slightly smaller diameter front tire, about 1.0-1.5mm smaller than the rear tires with a one way front diff.
This causes the front wheels to turn faster, thus disengaging the front wheel drive from the drivetrain, so in essence the front wheels are free wheeling via the one-way diff.
If you go into a bend a little too hot and the rear wheels spin out, the one way then engages and this causes the front wheels to pull the car out of the slide.
This works well in the larger scales like 8th on roads a-la Serpent and Kyoshos
Needless to say this is more suited to longer tracks with sweeping bends where you can carry speed thru the turns.
On a small tight track, where Micros tend to drive, a ball diff or standard gear diff is much more suitable.
Regarding Lessen's question, I don't see why it can't be done. You'll need to source a one-way for the M18, strip it down and reverse the one way bearings.
