What do you use to lube the o-rings in a carb when your cleaning? The high speed o-ring(s), low speed o-ring(s) and carb neck o-ring(s) as you put them back in. So they don't bind and tear?
I used a light oil, and now i can't get my high speed needle to hold a setting. This is on an OS 21 RG-X(P).
I've taken it back out and cleaned it off with alchohol and put some plumbers pipe tape on the threads of the needle when i put it back in. I didn't think this would be a good time to use thread lock, since it may be in contact with fuel.
Thanks.
Thanks.
