LST2 Shift Point, can't hear it, feel it or see it.
olds97_lss
RCTalk VIP
Dekalb, IL
I'm helping a friend try to get his LST2 broken in and working properly. This is his first go at nitro and I ran in to him while I was out bashing a few months back. We exchanged names/numbers, then I got a call from him last week... 2 months ago, he had a used t-maxx. 2 weeks ago he bought a brand new LST2.
He couldn't get it running. I went out and we spent a few hours beginning the break-in process. Everything went as I expected. The engine was finicky for tune/idle until about the 4th tank. The day was over (dark) and we left. He called me again today and wanted to know if I could help some more.
We spent the past 2 hours trying to get that thing to shift into second. First, we ran a few more tanks through it breaking it in and getting a decent tune. He had forgotten his manual and I know nothing about LST's other than I want one. He did remember that the 2speed comes from the factory at 5 turns out. So, that's where we started. Then 5 1/4, 5 1/2, 6, 7. Never do we hear it shift, never does the RPM's of the engine change or the does the truck speed up.
In the process of changing the shift point, we had dismantled the two speed entirely to make sure the shoes weren't binding or anything. They didn't seem to be. The only evidence on the shoe cowl (where it should be rubbing when engaging) that it was making contact was a small groove where the screw head made contact. The shoes look brand new, still shiny and the inside of the cowl has no evidence of shoe contact. No rub marks, powder, streaks, nothing. I had also cleaned off all excess oil (about 20 minutes into our session today) off the clutch shoes and cowling with DA.
I just don't get it. I've never had a clutch like this, so it's totally foreign to me. I've had 10 different trucks and 15 engines... but this clutch is kicking my ass.
Even with the clutch at 7 turns out, it would pull a standing wheelie off the line. And it just seems pretty slow. If it is stuck in second or something, then he is really disappointed at it's top speed. His old tired t-maxx could out run it after about 50 feet. I was hoping with that loose of a clutch, it would at least be stuck in second and we could tune down from there.
He doesn't have internet which is why I'm trying to find out info for him. Anything that anyone can think of will be appreciated.
You need to finish up the break in, and start leaning it some more. Then you'll see it shift into second gear.
If that doesn't help, maybe the 1st gear one way bearing is slipping and may need a good cleanup. Also I've experienced on both my LST's the clutch bearings trowing out grease in the clutch bell. That might be something worth checking.
Just reread your post, and realized that you had already tuned it.
Oh and another thing I just realized, maybe the HI/LOW shift nob is set in low. Make shure it's turned all the way clockwise.
Nope, it's on high. I think I'm treating it too much like a savage, revo or maxx with a very positive engaging clutch.
I posted in a LST specific forum and got a few responses with things to try. Many emphasized that it probably just needs more fuel through it. Also, that the springs/screws inside the clutch may be causing it to bind.
Yeah I just saw your post in my home away from home. It's very Losi specific, but that way you are almost guaranteed a useful response.
I hope you get your friends LST running right.
BTW did you see the LST2 roller in the FS section?
the shifting point is hard to hear but slowly increase your speed and you should hear it shift after i broke mine in it took me two tanks too finaly hear the thing shift with stok settings on the cultch good luck
