Well, I have installed RC Raven dual rate springs along with 60 weight losi oil and I like that it handles 5+ feet of air much better, but the slow rebound makes for weird handling.
I've been toying with the idea of putting a type of baffle/restrictor plate on the top of the shock piston to block 1/4th of the holes on the upstroke but to flex and unblock the holes on down stroke. So, I still get good pressure when it lands, but it rebounds more quickly.
Running lighter oil makes it bottom out really hard. Running the thicker oil I'm running helps avoid that, but gives me the slow reaction I don't care for. But, if I cover up 1/4 of the holes on the disk on the upstroke, I can run lighter oil but get similar results like thicker oil. On the rebound, the cover would flex and allow oil to pass through all the holes.
Any thoughts or confusion as to what I'm talking about? It may be something I try this winter... or if I see I'm going to get a lot of bashing time in yet this fall, I may try it earlier.
Your thoughts would be greatly appreciated.
