Sold / Found LST, MGT, GT, NT All Forsale, Pics. shown!
Status
Not open for further replies.
Butter Is Da Man
RCTalk Qualifier
Vineland
Losi XXXNT
-Trinity Finned Heat Sink Engine Mounts
-Trinity Aluminum Rear Pivot Block
-Trinity Heat Treated Vented Slipper Clutch Disks
-Trinity Threaded Body Teflon Shocks
-Trinity Blue Annodized Chassis Brace
-Trinity Aluminum Front Body Mounts
-Hardened Gold Shock Shafts
-Airtronics 94157 Steering Servo
-Hi-Speed Throttle Servo
-Kevlar Spur Gear (Stock Gearing)
-Graphite Upper Deck, A-Arms, and Shock Towers
-Aluminum Blue Anodized Upper Deck (Brand New)
-Picco Outlaw Exhaust Pipe
-Associated Side Exhaust Header
Comes with both Peak Racing Diablo .12 engine (installed), and a Fantom FR .12 engine, both side exhaust, and run perfectly.
This truck is basically an AD1 except for the chassis, which is the original XXXNT chassis. Comes with painted body with 3 heats of dirt oval racing on it. Spotless.
Would like $325, but reasonable offer will do.
Team Associated MGT
-Associated Factory Team Steering Assembly
-FOC in Tranny
-RPM A-Arms all the way around
-Lunsford Titanium Turnbuckles
-Associated Aluminum Diff Housings
-ProLine PowerStroke Shocks, with every spring made for them
-ProLine 23mm Hub Adapters
-ProLine 40 Series BowTies put on 23mm 40 Series Velocity wheels
-Envy Racing Bi-directional Slider Clutch (never worry about broken clutch springs ever again)
-Hitec 645 Steering servo
-Futaba 9304 Throttle servo
-Venom 1100 rechargable receiver pack
-Picco Outlaw 26 engine with Roto Start
-Associated Factory Team Header (pipe runs along chassis instead of wrapped around the back)
-XTM High Torque Exhaust Pipe
Comes with a painted ProLine F-150 body, and all the stock parts, along with a ton of spares. Also one extra set of tires your choice, after you buy.
Would like $350, but I'll take offers.
Team Associated Factory Team GT
-Peak Racing Diablo .12 Rear Exhaust engine with about a gallon on it
-Mugen Rear Exhaust Header
-Trinity Blue Anodized Touring Car Pipe
-Trinity Aluminum Blue Anodized Transmission Brace
-Trinity Blue Anodized Rear A-Arm mounts
-HG Aluminum Shock Towers
-Team Associated Aluminum Blue Anodized Shock Caps
-MIP Gold Shock Shafts
-T4 Front Axle Mod. (½ inch wider)
-RPM Receiver Box
-Futaba 9304 Throttle Servo
-GPM Aluminum Blue Anodized Throttle Servo Mounts
-RC Solutions Receiver Pack Holder (a must have so you don’t have to rely on zip ties anymore)
-MIP CVDs with brand new axle stubs
-Trinity 1200 receiver pack
-Comes with 3 servos; Hitec 625MG, HPI SF-2, and Futaba 9304
-Custom Painted Team Mel’s Shells Crowd Pleaser Body
-The following are brand new:
-Gas Tank
-Ball Studs throughout entire truck
-Ball cups throughout entire truck
-A-Arms
-Hinge Pins
-Front Bulkhead
-Front Nose tubes
-Bumper
-Chassis has about 10-12 races on it
-Clutch Bell Bearings
-Spur Gear
-Entire Diff has been redone with all new gears, cases, diff. balls, bearings, etc.
-Battery Tray off the back of the truck
This truck has enough extra parts to make an entire 2nd truck, and still have extras. I have accumulated so many parts, and have replaced, even when not necessary, that I never had to worry about having a spare. For example, it comes with 2 extra, complete diffs. ready to go.
Awesome truck. Won tons of races. Comes with 2 more bodies, one of which has 1 race day on it. I have all the stubs for the new parts that I mentioned to prove purchase, and will include them if wanted.
Would like $340, but I'll entertain offers.
Team Losi LST
-RPM A-Arms all around with camber link adjustment
-MIP CVD HD Axles
-Team Losi Aluminum Front Shock Tower
-Team Losi Aluminum Diff. Cases
-BAC Version 2.0 Steering Link
-ProLine 23mm Hubs
-ProLine 40 Series Crime Fighters on 40 Series Wabash wheels painted Black
-220cc Fuel Tank with Primer Sealed off
-Team Losi Hard Anodized Exhaust Pipe
-2ndary Lexan Gear Cover
-LST2 Clutch Bell
-Team Losi Thin Sway Bars all the way around (Thick included)
-Team Losi Gold Shock Shaft
-Venom 1100mah Flat Receiver Pack
-Mach 26 engine with about 3 gallons on it
-Losi Spin Starter System with 2100mah stick pack
-CNC made 14mm Aluminum Hexes
-Brand new Diffs (Gears, Cases, Bearings, ect) with 10,000 wt up front, and 10,000 wt. In the rear as well
-Extra Mach 26 included with runs great, and is a perfect backup
-Custom Painted Team Mel’s Shells Dodge Quad Cab Body with 2 race days on it.
I had 2 LSTs at one time, and decided to focus on one, and make it the best I could. So I broke the other truck down into parts. So there is another truck there, except for another chassis, which I sold to a friend. I mean I have so much stuff for the truck. Everything you can think of is in there. I have about 6 SETS of stock a-arms. Full sets. Comes with about 20 axles. Yes, roughly 20. Never worry about buying anymore. Turnbuckles, gears, steering parts, shock towers, knuckles, you name it, its in there. Comes with a FOC Tranny complete, just needs a rebuild. Also comes with an extra set of tires, your choice, after purchase.
Great Truck. Won a lot of races for me, and will for you as well. Comes with 2 more bodies, including another Team Mel’s Shell custom paint job, this time on a Team Losi Racer body. A great Truck for the collection.
Would like to get $425, but I'm open to offers.
Pictures of trucks shown, but there is limited room. I have more pictures of the bodies off and everything if interested. Please e-mail me at [email protected] if you would like more pictures. Thanks.
Status
