XashBE
So, i'm planning to turn my Corally Asuga into a power drifting car (don't argue if it's a waste or not, i just wanna ^^).
For that i obviously have to get it a bit lower as well. And well, since i'm at it, i also want to make it be a little lower (1-2 cm max!) on the front than the rear, giving it the 90s tuning look. Now, what's the better option?
- use different sized tyres which will stress the diffs a bit. Here i ask myself: how much stress are we talking about? I mean, the diff is meant to handle things like this, no? Or is the permanent stress too much?
OR
- simply get shorter shocks in the front (the front shocks for the Corally Spark are 107mm while the Asuga ones are 117mm, which would give me a rather simple solution. Sadly the back will not be lowered at all by this and i would still need a solution to get the overall chassis to be lower
Another solution would be a fully set of new shocks. I'm looking at either some Pro-Line ones (but they seem too soft in the base setup and would require springs as well) or TLR ones ( TLR243048 & TLR243049) which would give me 110 and 123mm. That would make them 7 & 6mm lower overall than the standard ones. Might not be enough though.
Any other suggestions?
Mind you, i am sitting in the EU and parts don't come as easy here as in the US
If you're interested on my building progress, you can check on it in the Corally forums. Actual stuff starting at page 3.
OR
