lmk what you guys think
any other hopups or upgrades i should get???
i put alot into this truck, and has payed off well.
has
axial .28 Spec 1s (have LRP Z.28 Spec 3 waiting when axial blows up)
all 4 Titanium nitride shock shafts
all 4 corners of Titanium nitride hinge pins (inner and outer)
titanium nitride spur gears and clutch bell gears
integy aluminum side skirts
spektrum z590m throttle servo
maximizer +1 inch beadlock rims
zombie max's
hard anodized aluminum shock bodies with aluminum adjusters
hard annodized diff cases
hard annodized skid plates
hard annodized finned engine mounts
GS racing dual chamber aluminum tuned pipe
Reedy 1100 mah reciever pack
Dodge RAM2500 mega cab body (custom painted with metallic flake blue w/ carbon fiber flames)
rear aluminum body posts
rpm a-arms all the way around
rpm gear cover
high performance brake pads
ofna throttle mod, (with a few add ons and adjustments)
3 piece clutch shoe racing flywheel
ofna aluminum clutch shoes
aluminum engine support brace
motor saver air filter
foward only transmission conversion
already planning for
. titanium driveline
. graphite top plates
. aluminum shock caps
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 410KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 431KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 386KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 408KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 394KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 416KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 428KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 397KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 379KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 387KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 401KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 385KB.
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768 and weights 370KB.
sorry guys i know the pics dont work....
try this link to the other conversation i had going about lst's
its got the pics in it
https://www.rcnitrotalk.com/forum/showthread.php?t=52145
heres the link to my other thread with the pics of mine...
enjoy....
also am using link because pics get messed up when i link them.
