Losi 22 5.0 set up
PAC
Hello there..
I'm a tekno guy and recently aquired a losi 22 5.0 AC..(No 2wd for Tekno ..Yet?)
I am in the process of converting it to for clay .
I have set up sheets from Frank Root and i am going side by side from kit setup to his.
Some of these are a bit confusing (for now)
Pivot height..Do i need to purchase an LRC block?
Spindle ball stud..Not sure where that is located.Kit is standard ..Looking for "Low spacers"
Axle height..Where is this adjusted?
Toe plate..Do i need to purchase a block for LRC?LRC -2 is kit set up
Toe inserts..I assume these go in the C block
Any help explaining some of these setting would be appreciated..I have all Teknos and got used to the setups
I'm sure Ill eventually get how losi cars work..
Thanks in advance for any help on this
This is an old thread,
I hope you figured out all of that cause I had to figure it all out and I'm a rookie
