Here are the basics that should make any healthy engine run right.
Put the nose of the truck against something firm so it can't get away from you. If you have an EZ start, keep it running while moving your LSN one way or the other till it starts to run.
Adjust your LSN and idle screw till it idles well and will run up to half throttle. (get it to running temp before you finalize any settings) Running temp at idle shouldn't be more than 200-215 or so. When it idles properly, throttle it to half and see if it stalls or bogs down. If it stalls, it's too lean. If it bogs, it's too rich.
Now go to full throttle. This is when you adjust your HSN. Same thing. If it bogs, it's too rich, stalls, it's too lean.
When it seems to be running good, pinch the fuel line. It should speed up slightly and then stall within 3 - 4 seconds. If it stops quickly, your LSN is too lean. If it takes longer, the LSN is too rich.
Drive it for a while and then take a temp check to make sure it's at the proper temp. If it's too hot, richen the HSN.
You will have to make small adjustments on the HSN almost daily to compensate for outside temperature and humidity.
By the way, the factory settings are for break in, or a starting point if you really messed things up. Once an engine is broken in, don't expect it to run right by going to those settings.
