Well, I am glad I watched a couple of the vids. I like the track a lot. Wide open, lots of flats, no pinch points, and no weird jumps. Only thing I do not like is the crossover section and no long straight.
OK, the track looks somewhat hard packed and dry and has no blue groove, but is not loamy. Watch your shock settings. You want maximum traction with low rebound. As far as diffs, leave the center alone and try even amounts front and rear. (See, Plaid's tip about having a second set pre-filled with optional viscosity makes sense) Maybe 3-5-3. Hard to tell. Watch tire set up too. Need a lot of bite on the tire, and a bit more toe in than normal. Other than that, I am not good enough to make further recommendations without actually being there. Maybe Mxboy or Kx250 can help.
