The Titan 12T might be ok for the money but they are notorious for having very short lifespans. Some people get em to last a year but a lot of people say theirs died in a matter of months if not weeks. If you have no other choice but to run that exact motor then it is what it is.
I've heard the same short lifetime about the 12 turn Titans
But my experience since January of this year I have went through two of the VXL motors and two ESC
The Velineon 540/550 can on 3s I got the truck in January on the 8th battery I broke a right side front drive shaft but even after taking it apart and drying it by hand because I played with it in the snow the ESC overheated when I sent it to Traxxas to be diagnosed they told me there was rust in the motor and that's what caused the speed control to overheat
Neither one of the heat protection shut down worked
And Traxxas was pretty clear that their waterproof system does not mean rust proof so 33 days after I got my truck home the warranty was voided dude what they said was a bad motor I put just a cheap 4370 kv Leopard ESC and I've not had any problems I'm running 15 tooth pinion and 54 tooth spur
And the temps average 125 or lower and that's constant running not hammering on it but driving it on hardpack I also put the nine turn leopard motor on it with a 19 tooth high speed pinion that came with it and then the
Do you have to use the stock brushed motor or can you use the stock brushless motor? If you can use the stock brushless ESC and motor then Id upgrade to VXL3 brushless esc and motor combo. I'm assuming if you can use the stock brushless ESC then I'm assuming you can use the stock brushless motor too
get up about 140
So have you ever heard of rust in a brushless motor causing havoc in any of the other systems?
the Titan 12T motor is a POS and it can not be rebuilt. IDK what the rules are of your class that your racing in so i dont even know where to start suggesting anything. If you can run a VXL3 ESC does that mean you can run a brushless motor?
I live in Michigan in January of this year I bought a VXL Traxxas Slash 4x4 I read the manual and did the best I could about taking it apart cleaning everything up and drying it out after I played with it in the snow
Just after the electronics warranty expired the speed control burnt up
At that point I had only ever put the 19 tooth high speed pinion on once and did four speed runs on the road out in front of the house
Otherwise it was set up with a 15-tooth pinion and 54 tooth spur gear and the temperatures were between 75 and 95°, both the speed control and motor have a fan on them
90% of where I drive is on a paved bike trail
I get to the park pick my truck out put it on the ground and I bet it does not go 20 ft before it's smoked the ESC because it was just out of the warranty I sent the motor and ESC back to Traxxas they tell me that there was a little rust inside the brushless motor and that's what caused the ESE to overheat without using either one of the thermal protections
And that I'd have to replace the speed control and the motor but because they have the Traxxas always return policy it's only 55 bucks for the ESC and 65 bucks for the motor after I send mine back in
Just out of curiosity I had bought one of the brushless leopard ESC and motor combo from Amazon a 9 turn 550 can with a 4370 KV ESC
I have not had any problem with that setup other than I can feel a micro delay in the throttle I just reordered the VXL speed control I hope I have better luck with this one but since I'm relatively new to the RC world I wanted to ask somebody for their opinion just to make sure I don't overlook something and burn up this other speed control
The Traxxas tech on the phone told me waterproof does not mean rust proof
I did rebuild the VXL velineon motor I did not see any rust inside it but I did new bearings and bushing just to know it was new
Right now I got the velineon 540/550 with a 15 tooth pinion and 54 spur gear The temperature outside was 87° and with that setup my truck never got hotter than 125°
I also got the motor that came with the speed control that's a nine turn 4370 KV and on that is a 19 tooth pinion
After 5:00 or 6 high speed runs the temp gets to about 1:45° and that also was a 80° day I guess one of my main questions would be because I am using the 4370 leopard speed control which is just a little bit bigger than the vxl3 as far as KV so would that help the system run cooler cooler?
And what do you think about rust and a brushless motor causing the speed control to overheat?
Any advice would be greatly appreciated I'm new to this forum I did try to look through some of the history to find an answer before I ask but I did not see anything related to what I'm dealing with or got questions about so thank you
