loctite
shakey2
whats thebest loctite i do mechanical work so i have about 4 different one and can't see buying from hs
A little goes a long way.
Blue for sure. Holds them in place and not hard to come out if you need to
I usually use the Blue #242 liquid or the blue LocTite stick that I bought from Team Fast Eddy.
thanks
thanks guys was torn between blue and purple red i only use in extreme applications like header bolts on my 327 sm block:D:D
thanks
Since so much uncertainty abounds in this thread, let me suggest the blue.
thanks man still wondering from mt tread about idle found leak its oil off the exhaust can't find a gasket do you think the hi temp rtv will hold
sorry but your going to have to post a newthread about that..
this one is about BLUELoctite
