listen to this can u help
shorty
did you temp it if so what were the temps??are you sure its coming from the carb and not the pipe..my tmaxx did that a few times after i put the sirio bb pipe on it...
in that case i whould say to richen it up a bit.your probley running to hot.try that. and get a temp gun..you can do a spit test put some spit on your finger and touch the head after it warms up.the spit should evaporate away slowly..this is not right way to go about it but will work..if it sizzles away fast you are to hot..i hope this helps
oh and a nother thing were you out running your truck or did you just let it sit there and idle when you took the vid
ok what about the running thing do the same
:lurk:
ok then richen up your lsn but do it in 1/8 turns..lleave your hsn alone.sounds like you have never touched it befor after break in..
try that and lmk..what the out come is..
Deffinently richen it. If that does not fix it. Buy a temp gun and then get it in the right temp zone!:boating:
ok ill try it 2morrow and LUK what happend:thumbup:
Sorry to be off topic but......
I contributed 25 bucks yesterday, how long did it take yours to register?
(where it says contributing member under your name)
:tophat: :tophat: :tophat:
Yeah. Sounds like something is boiling. might be fuel in the pipe. Or could be the carb like they said..
Try to do a little righening like they say.
Temp gun is a must for 30 bucks.
Woodie has to get you all set up. It depends on how busy he gets. Usually with in 48 hrs. He had me set up real quick because he was on line at the time. Welcome to the stable its always good to meet the new pony. We will see you in the contributors forum when you are all set up.
Thanks for giving me a welcome note:jester: :jester:
This forum is one i stumble on from google, if i dont get to it myself(i never see him) could you tell him i said thanks for making such a great sit!:cheeky: :buggy1:
SORRY FOR BEING :OT: AGIAN:sorry: :sorry:
corectrion *site*
