Kyosho M.P. 7.5
IversonMino
Are these all the parts i need to build/start my buggy?
O.S. .21 RZ VO1B
O'DONNEL GLOW PUG .21 ENGINE
O.S. SUPER AIR CLEANER 201
O.S. T-2050 SILENCER HEADER SET
KYOSHO MAXIMIZER FUEL FILTER
HITEC AGGRESSOR 3-CHANNEL FM/1 HS325 SERVO
Hitec HS-1525BBJ Servo Hi-Speed J
PROLINE TIRES- 1/8TH KNUCKLES (XT?)
ASSOCIATED SHOCK OIL 30 WEIGHT 1 OZ.
STORMER Rac3-SHOE CLUTCH SET
KYOSHO TCD GEAR OIL 7.5
KYOSHO POLYCA- RED/WHITE
IS THIS ALL I NEED TO MAKE IT RUN?
What type of 7.5 kit are you getting?
1)You'll need a starter box
2)The engine will come with the air filter although an extra is nice to have
3)You'll get what you pay for on servos, don't skimp there
4)Get some 45w shock oil for the front and 35w for the back, a good starting point.
5) RB, Rossi, Rex, Top are all good pipes you may want to consider
6) The clutch that comes with it should be fine
7)You'll only need the TCD gear oil if you get one of the Kanai kits. Otherwise, 3,000 for the front, 7,000 for the center, and 1,000 for the rear will do fine
XT is a good compound to get
Battery Pack
Failsafe
Receiver
Second Servo for steering
Does that header set come with a pipe?
Maybe 35-40 weight oil for the shocks.
Oh sorry - starter box - the new OFNA Wide with the BIG motor kicks major ass!!! 54$ if you shop around.
