Originally posted by militarymaxx
Just finished re-building my shocks just moments ago. I know of two methods. I will pick this up after the body has been filled and all the air bubbles are out. Method #1: with the body full of oil level with the top and the piston at the bottom, making the shock at full extension, slowly screw the cap on. Done. Method #2: same as #1 but the piston is near the top and when putting the cap on you make a few turns then lower the piston down a little, tighten the cap some more, pull the shaft some more, continue until the cap is tight and the shaft is at full extension. I have never had any luck with method #2. The shock would only compress half way and then become solid. Method #1 has always worked well for me. The important thing to remember is to get all the air out. Cycle the piston up and down, working the air bubbles out. Let it sit for as long as needed until no more bubbles. Good luck, and let us know how it turns out.
