uDi_MP7.5
Diff rebuilds won't cure that. Whatever happened there is not normal anyway, clean it out, and if it happens again, be worried - because it's not normal.
I don't touch my K2 diffs any more often than maybe once in two gallons and i'm a pretty avid wrencher, and if you set them up right to start with you could go double that easy without needing to rebuild. And for the sake of it, when i open up my diff cases I see nothing but a bit of excess black grease which has been flicked off the gears.
To help keep the universal pushed a little deeper into the cup, what you can also do (my memory just kicked in this morning) is use some small washers between the universal end and inside bearing of the hubs. So put a washer or as many as needed, onto the universal end, and then slide it into the bearings. Some of those specific washers should have come with your kit, and you could probably find some more.
You can only go so far before the dogbone end gets pushed in too tight, so make sure you check after each time you do it.
That combined with FRB's method (use fuel tubing, there's more cusion than plastic washers) you can get maximum up travel, while not having the end pop out.
