Ok here is a link to buy one of the mods:
http://www.innovative-rc.com/innovativerc-tank-p-312.html
But most just search and read and build it the way you want it.
Here is a link to many builders mods. Also a great forum for savage owners.
http://www.*******************/forums/forumdisplay.php?f=119 EDIT: I GUESS I CAN'T POST THESE LINKS HERE. WELL TYPE IN HPISAVAGEFORUM DOT COM AND GO TO THE MID TANK BUILDS THREAD AND YOU WILL SEE MANY MANY BUILDS ON HOW AND WHAT TO DO. (IMO SIGN UP AND CHECK THE SITE OUT)
And this one is mine
http://www.*******************/forums/showthread.php?t=13347 EDIT: I GUESS I CAN'T POST THESE LINKS HERE. IN THE MID TANK BUILD THREAD FIND DIVEY MID TANK MOD ON XL AND MORE AND YOU CAN SEE HOW I DID IT ON A REGULAR EXT TVP USING ALUM.
Mine has changed by getting FLM LCG TVP's which make the 250cc ofna tank mod easier and the servo relocation easier becuase the tvp's are set up for this. And here is a picture of it now:
I'm not going to go into detail about everything but check out all the links I posted and with some creativity you can accomplish what I did and even better.
The first picture is the relocation of the reciever box using a rpm boc mounted on the side, the next picture is the relocation of the battery box using a hellfire battery box, the next picture is the relocation of the throttle/brake servo (hitech 5645mg) which has the ofna throttle/brake mod but with the execption of the throttle linkage is directly attached the the carb slide with no other linkages like in the normal one, it produes less drag and a super fast response even with that servo, the next picture is the ofna 250cc tank mounted, and the last picture is the relocation of the steering servo (hitech 5955tg) with a killer robtronic alum servo arm.
Now on these pictures is with the new tvps so mounting everything was alot easier. Now on my link for my mid tank mod the regular ext tvps were used and I show you how out of aluminum. Any questions feel free to ask. It's a working progress and it's almost done. Thanks Terry
