Just check it every gallon or so. You should be ok with that. If it starts acting lean on you for no apparent reason, a clogged filter could be the cause.
cbreaker said:The air gets thinner as it get colder, so it runs the engine leaner. The warmer it is outside, the more dense. Just one more thing to keep in mind while tuning these things =)
CorradoPsi said:actually you have this backwards. air gets more dense as it gets cooler so your actually packing more air into your motor which causes it to lean out. when its hot outside the air is less dense, but some people find themselves richening up the motor anyway to combat the ambient heat. if you have a good cooling head. you will be leaning out when it gets hot outside.
AC48 said:What do suggest for a tire that will last long and be used only for bashing? I mainly drive on grass, pavement, and some times dirt. Thanks!
