Hi all, been a while since I asked questions here, but seems like I'm in need of advice again as I'm out of ideas and at my wits end
My rig is a wholly stock hpi rs4 evo3+ with the stock engine Nitrostar T3.0
Firstly I can't seem to get it tuned no matter what
The problem is during some high speed runs (1/2 throttle or more), SOMETIMES it bogs down when I put 1/2 to WOT throttle (quite uncommon occurrence, but is guaranteed to happen). What I mean by bog down is that the engine's tone suddenly becomes a low pitched sound, and sputters, before stalling.
There is good amount of smoke coming out of the car during acceleration, and less smoke when the car is already running fast (maybe because of the wind, cos its already moving quite fast) so from this, I assume it is a HSN rich bog.
So I've tried leaning the HSN, but I'm at the point where if I lean the HSN any more, the idle becomes too high the clutch engages. OK so then I should richen the LSN to prevent this, right? But if I richen the LSN any more than my current point, the car will bog on acceleration.
So I'm trapped in a box as you can see
Here's some more info:
Idle temp: 200-220 (shell on)
High speed runs: 250-260 (shell on)
(temps above appear OK to me)
Pinch test: 2 seconds, revs up and then dies, so LSN seems OK.
I've considered the possibility that my high-speed run stalls may be caused by a Lean bog, in which case I should richen the HSN. But if I do this, it will bog on acceleration from stationary (in which case I should lean the LSN, which DOES help this, but the idle would be too fast and clutch engages). With a rich HSN, I've never had the opportunity to go high speed and see whether the WOT-bog still happens, because it always bogs down on initial acceleration.
PLEASE COMMENT, much appreciated!
My second, much simpler problem is probably easily fixable. My engine is easy as hell to start when cold, but impossible to start once warm. Could it be vapor-lock? I doubt it, I tried rubbing alcohol on the carb to accelerate cooling until it was room-temperature (while piston was still very clearly very hot) and it still won't start.
As the rotostart is spinning the hot engine, I hear signs of life, i.e. the knocking sounds which tells me there is some combustion going on, but the engine just wont fire up.
OK so it might be pre-ignition? hot engine = fuel igniting too early = can't start? Maybe. I did recently change to the OS 8 med-hot glowplug, but the stock glowplug was cold-med. Could this be the problem?
Thanks for your input
