jt hybrid chassis
maxxmasher8
i have a jt racing hybrid chassis and for the first time i have stripped the gear. i need some help. the brand is ho-bao and it is a 65 tooth that fits on the center shaft adapter. if anyone has this truck and knows what I'm talking about please reply!! and if anyone else has heard of ho-bao or knows where i can get this spur gear please say so!!!!!!!!!!!!!!!
maxxmasher8
maxxmasher8 said:
... and if anyone else has heard of ho-bao or knows where i can get this spur gear please say so!!!!!!!!!!!!!!! maxxmasher8
Yeah, i've heard of em. sorry can't help ya with the finding of the part.
ho boais ofna. Its just a standard 1/8th scale buggy spur i think.
is it the plastic type or metal?
and is it a solid spur gear or does it bolt on to something other than the diff cup?
and Pierow is right Ho Bao is OFNA, but it's supposed to be the crappy stuff.....
it is plastic but i would like for the one i get to be metal and yes it is solid except for the hole in the middle to fit on the diff cup adapter.
thanks for the info so far
thanks alot plaidfish thats just what i needed but i found a steel one by powerline racing for 16 bucks so i might give that a whirl but its 63 tooth also.
i guess i did i ordered about 8 thi morning and also, i think it is 65 tooth because i enlarged it counted the teeth and there were 65 so i guess it was a good find. at first i thought it was a 62 tooth because i emailed them and they said it was the same as stock and i thought the stock was 62 but i guess they meant the stock 65 tooth plastic one. i am happy with the find though so now i dont have to regear it!!
tyler
Does your center diff cup have a plate that this bolts to?
I am trying to do a custom setup w/ a mutant maxx and I'm having a hard time finding part data from different mnfgs. and id the plate (if that's what it is) an OFNA part or a JT racing part?
yes it does bolt up to a plate and here it is
http://www.renegaderc.com/shop.mv?Screen=PROD&Store_Code=RRC&Product_Code=OFN1897&Category_Code=
but then my whole set up is this with all the extra brake parts and all of that
http://www.renegaderc.com/shop.mv?Screen=PROD&Store_Code=RRC&Product_Code=HRC-3-Havoc&Category_Code=
if you would like....if you like this center diff assembly...i could find all of the parts you might need like brakes and all of that but just reply and ill see whats up
tyler
all I need is the plate that bolts to the diff cup and then the spur gear bolts to it.....
JT racing never answers my e-mails requesting it so I'm just done w/ that end.....and I can't find the part on the oFNA site.....I'm going to call OFNA tommorow and ask for one..
