JR's XS3 FM computerized RC system
ByPS
RCTalk Racer
Czech Republic
Hallo every body,
I have chance to buy new JR-Propo XS3.
I want ask you for troubles, adventages and so on.
Do you have expirience with it? Is it stable no problem RC control?
Thanks a lot for the answers.
Well, If you don't read the directions and know how to work the servos to utilize their capabilities then you may have a little problem. I think that you should be fine.
jon2,
I plan to use this RC in my Revo. The servos inside box with XS3 I do not plan to use.
In this moment I did notread manual, I am not having it right now.
Please, tell me more about problem with servos?
I Revo I am using the Traxxas stock servos. In future i plan to use digital HS-5925MG servo for throttle and break.
Here is quick link from where I plan to buy the XS3:
http://shopping.rcmodel.hk/product_...=2848&osCsid=79342e85356d356dd68ee39f69e2f51b
Here in middle Europe the JR's distributor is Graupner.com but they have labeled it like XS6 with memory from ten models, all other looks the same but XS3 is a lot cheaper.
ByPS said:
jon2,
Didn't meant to alarm you. All I was saying is that you have an option for "F" or Fast frame rate for digital servos. I use the other option which the name escapes me.. Servos are pretty much ALL ok I would think. I would just pick the right servo's for your Revo. I would invest in a higher MAH rated RX pack.
Your TEN model memory XS6 is the PRO version I think here but your RX is not the same. It is for the regular XS3 where the pro has the smaller RS310 ..
You will be fine man :cheers:
Oh yes. The Fast Rate. Thanks for explanation.
But I do not unedrtad for little words (I am not english man, excuse me).
What is meaned by this: "Servos are pretty much ALL ok I would think. I would just pick the right servo's for your Revo. I would invest in a higher MAH rated RX pack."
Try simple english to me, thaks a lot.
With the XS6 you have right. My friend have one but with bigger Rx. Now who bought XS6, have smaller Rx.
And this bigger Rx is possible to plug into Revo's receiver box? I look like you have XS3, Don't you?
