Joshua's TMaxx
Springfield, MO
  2. Flying
Here's my Tmaxx. It started as a 2.5 and over the course of a year and $2000 I have a bulletproof beast. Here's a list of the parts I've put in it:
[ ] New Graphix Body
[ ] Wheels and Tires
[ ] Spektrum Receiver
[ ] 30% Nitro Race Fuel
[ ] OS .21 TM ABC Motor
[ ] OS--2070 Monster Truck Exhaust
[ ] 3.3 Transmission
[ ] Robinson Racing Hardened Steel Clutch Bell 19T
[ ] Robinson Racing Steel Forward Only Conversion
[ ] Robinson Racing Gen 3 Slipper Clutch w/ Hardened Steel Spur Gear
[ ] Savox 500 oz Waterproof Steering Servo
[ ] Stainless Steel Screw Kit
[ ] Fuel Line Clips
[ ] Ceramic Motor Bearings
[ ] Titanium Front & Rear Skid Plates
[ ] Titanium Shock Springs
[ ] Titanium Hinge Pins
[ ] Titanium High Load Motor Screws
[ ] Aluminum Differentials Front/Rear
[ ] Aluminum Rear Differential Locker
[ ] Aluminum Lightweight Flywheel
[ ] Aluminum 3 Plate Clutch
[ ] Aluminum Slipper Clutch Eliminator
[ ] Aluminum Lower Brace
[ ] Aluminum Lower Skid Plate
[ ] Aluminum Motor Mount
[ ] Aluminum Throttle/Brake Servo Mounts
[ ] Aluminum Steering Servo Mounts
[ ] Aluminum Big Bore Shocks
[ ] Aluminum High Flow Air Cleaner
[ ] Aluminum Steering Bellcranks
[ ] Aluminum Servo Saver
[ ] Aluminum Fuel Filter
[ ] Aluminum Fuel Cooler
[ ] Aluminum Wheelie Bar Wheels
[ ] Traxxas Steel CVD Axles
[ ] Traxxas Steel CVD Driveshafts
[ ] Traxxas Body Clip Retainers
[ ] Traxxas Wheelie Bar
[ ] Traxxas 1600 Mah Receiver Pack
[ ] RPM Bulkheads Front & Rear
[ ] RPM Suspension Arms Front & Rear
[ ] RPM Axle Carriers Front & Rear
[ ] RPM Shock Towers Front & Rear
[ ] RPM Crossbraces Front & Rear
[ ] RPM Rod Ends
Its not so pretty anymore LMAO I've definitely bashed the heck out of it.
[ ] Fuel Line Clips
[ ] RPM Rod Ends
That is so sick????????
