Jato stalls when braking
Will26
RCTalk Champion
Around Maryland
  1. Racing
I've decided to check out my carb after numerous stalls and this is what I found. At neutral the throttle is open a little allowing air in. At brake it closes all the way, choking the engine and forcing it to shut off. Has anyone else had this problem? How can I prevent it? Pictures:
Here is the throttle at neutral
Here is the throttle when it brake
You need to pull your brake while adjusting the gap screw and gap to 1mm. That way when you brake the carb only closes to gap setting and not all the way.
Now I get it. I was confused because if I increased the gap space, it also increases the idle speed. I wasn't even thinking about the idle screw. Lol. Thanks :D
