Jato parts
DDJIMMY
I broke my front a-arms. Whats the better replacment stock or aluminum.
I'm went through 2 sets of stock ones. Have some rpm a- arms on the way. Thanks
jato tires/ sway bar foam tires for jato get jaco no jac2040 rear, jac2020 front, dont for get it move the bearings and spacer to the new front tire. get k&s 1/8 music wire and make a new sway bar for the front and back, just bend it like the stock one, only make it longer, dont use heat to bend it that will mess up the temper. use zip ties to hook it to the lower a arm. replace the stock screw with traxxas #4859 flat head screw. then use zip ties on the shock springs to lower it as much as you dare. these changes made my jato into a different car. oh oh do not run the jato with out the right hand dirt guard, tire dust will get into the engine clutch.
i have all team integy arms front and rear. also have the steel driveshafts, aluminium tie rods and turn nuckles.
