i just put a O.S. 21tm engine in my jato. so i thought at the same time, i put a check valve in the pressure line, from the exhaust pipe to the fuel tank. so i put a check valve near the ex pipe. a sullivan s756. then i put a air bleed in the same line near the fuel tank, to even out the pluses. by useing a "T" fitting. i covered one end with jb weld, then drilled it with a .040 drill. i havent ran it much, but it screams. i dont know how much help the check valve is, but i screams. oh did i mention it screams. NOTE: iam NOT recomending this to you. if you do this, you are on your own.
