Jato 3.3 and Revo 2.5 restarting issues
HDRIDER56
RCTalk Qualifier
Delaware ohio
  1. Crawling
Can anyone give me some suggestions on what to do about my engines not starting again the following day after I've had them running fine the day before. All set to factory settings still, backed down the idle some so they're not racing. Both engines have been rebuilt since getting my RCs, one thing to note. The pistons in both do travel close to the top of the sleeve. I've seen some videos about the pinch spec. How much would this effect starting and restarting?
I'd put the idle back up first. Should be .5-1.0 mm gap in the carb. Anything out of the range is no good.
Next check the glow plugs and make sure they are ok.
This is correct. 👍
The racing idle is prob from an air leak, cracked orings. Buy new orings and use green slime to install them. Reset the carb and see how that goes.
Good luck! 😎
Glow plug us brand new, using a separate igniter. Got tired of fighting that EZ start no light glow plug issues. My idle gap is right around .7, if I didn't mention it both these cars i received on the cheap for rebuild projects, the Revo was free a d the Jato was a $125. Had to get new radio systems for both. Went with the TQI/TSM with Bluetooth chip. I can get them running great one day, come back the next day or two and nothing, sure I've flooded them once or twice in the past.
Is there anyway to check the piston wear? I know you can't really do any kind of a compression check?
Did you reseal the motors when you rebuilt them? What did you use? How long ago?
Compression is ptetty easy to determine by resistance on a pull start. You can turn your flywherl by hand to get an idea too.
If it spins real easy, theres an issue.
The pinch or lack of pinch should have been pretty obvious when these motors got rebuilt. 🤷‍♀️
What do you mean by reseal? I used assembly lube in the beginning, I seen it was too thick and switched to Marvel's Mystery oil. Yes I could rotate the motor using the fly wheel and felt semi firm resistance at too of the stroke, the pistons were going almost to the very top of the cylinder.
I can't open the attached pictures in the post? Assuming they're important?
