Gundragon
RCTalk Qualifier
Ok Fellas/Ladies,
I am noticing something about my Slash that was starting to bug me a bit. The car starts doing a "stutter". I looked in the manual and it says the following: 1. Motor capacitors broken or missing - check and replace capacitors, 2. The receiver ot Antenna is to close to power wires or the batteries, 3. Bad Connections - check wiring and connectors, 4. Motor worn - replace the motor, 5. Excessive curent to motor - use milder motor or a smaller pinion gear.
Now, this being a new rig, I can pretty much shoot down 1, 4, and 5. So I look at numbers 2, and 3 and do not see anything that looks like a bad connection, so I am down to option 2. The receiver to Antenna is to close to power wires or the batteries. So ok, that makes some sense being that I set the receiver on the ground next to the truck and it will seem like it is about to launch. I go and buy a ramp for the rig now and am thinking everything is ok. (By the way, batteries are brand new and the pack is fully charged and I wait for the charged battery to cool down first before I mess with it too to make sure it does not run super hot.)
I start making a couple jumps with the rig and then I notice something else happening now. As I drive the truck back by me it is like stalling. The best way I can describe it is like it is stuttering when I drive it. I am not seeing any connections that are loose (thinking maybe something might have come loose from the jumping) but do not see anything. Any ideas as to where I need to look now?
On another side note, I am reading in the manual about the adjusting the Slipper Clutch and wanted to do as it says about the Achieving a good starting point for the slipper clutch, i have to adjust the nut clockwise until the slipper clutch adjusting spring fully collapses. When I am trying to adjust it the back wheels are moving and I am not getting anything. Am I being two gentle and thats why I am not able to adjust the slipper clutch or the little movement I am feeling on this already is exactly what I should be looking for?
