Hi!!! I want to buy I car but I don't know if that's a good car so I came here and I hope You can help me....
It's a 1/8 Nitro RC Truggie 4.6cc with the folowing Specifications:
Engine: .21 W/VX
Transmission: Front, Center, and Rear Geared Sealed Differentials
Gear Ratio: 1:17.5 Single Speed
Drive System: Four Wheel Drive
Radio System: Two Channel AM Digital Controller
Length: 530mm
Height (Overall): 205mm
Wheelbase: 365mm
Front Tires: Off Road Knobby
Rear Tires: Off Road Knobby
Wheel Diameter: 120mm
Wheel Width: 82mm
Differential Type: Four Bevel Gear
Chassis Type: 2.5mm 6061 Aluminum Alloy
Brake Type: Dual Steel Disc
Fuel Tank Capacity: 125cc
Suspension Type: Aluminum Body, Oil Filled Shocks
Ground Clearance: 55mm
Weight: 3800g
Features
1.Four wheel drive system
2.Powerful Suspension arm with adjustable width
3.High quality main and diff. gears
4.6061/T6 anodized aluminum radio tray and chassis
5.Solid universal joint cups/High quality ball bearings complete
6.Large off road slight block tires and spoke wheel rims.
7.Disc brake system provides quick brake response
8.Extra large leak proof fuel tank with spring loaded fill cover and a long fuel pipe for quick re-fueling.
9.High flow duty foam air filter (Anodized aluminum capped cover is for optional use)
10.Polished exhaust pipe and manifold
11.6mm aluminum rear sway arm.
I hope you can help me becouse I don't know if it's a good car or not!!
I let you some pictures:
Engine: .21 W/VX
Length: 530mm
Wheelbase: 365mm
Wheel Width: 82mm
Weight: 3800g
Features
