Glad to hear the trash bag method worked out as planned. Everything is looking good. I'm kind of sorry I don't need one of your chassis, they are sweet!
Well as cool as the trash bag method was, there was a similar much better solution for purchase
Guess I shoulda looked around a bit, lol.
This worked flawlessly, was quite quiet, and wasn't hard to clean up afterwards. I also bought an attachment that puts a brush around the bit that has a vacuum attachment. I didn't use it this time because I really needed the parts I was cutting and this was my last piece of CF. I'm not sure I'd run the vacuum for fear of small sections that get cut out getting sucked up, but I could try. The reviews show that the bristles must be trimmed/adjusted or the Z movement can jam. If this works though, that would make cleanup almost unnecessary. I did fashion a second, thick foam filter on the exhaust of my shop vac, and I'm confident there isn't any dust getting anywhere when running it. I guess then the issue will be emptying the shop vac which I think I will do by filling it with water and dumping that into a bucket or something or maybe a disposable cloth sack. Not sure on that yet...
The weather saturday was bad, so I was home and decided it was a good time to tear down the engine and replace the bearings with the ceramic ones I bought.
I also wanted to do some other mods with the crank, and be a little more aggressive with the sleeve ports. The engine parts were all very clean and in great shape. Then again, the run time isn't much for a drag car. I was pleased to see that the crank for this engine already had an existing scallop (some engines don't have that at all). It was a little sharp on the edges, so I smoothed it out some. Not much of a change, just something I've seen guys do to improve the flow and reduce turbulence.
Here you can also see the rod pin is hollow - this is a nice feature of the KE25, there is a spring and pin that goes in there, and it's used for a ratcheting system for the pullstart. There is(can be) a OWB, but when the engine is running, that rear shaft doesn't actually spin, and removes all of that rotating mass that a OWB normally creates.
I also wanted to ramp the shaft. This improves flow, and creates more pressure in the crankcase, and is a mod for improving the low end response/power.
I then worked on the sleeve, and wanted my port fangs to be a little better defined and bigger.
I was careful not to go into the nickle plating of the inner sleeve.
Now it was time for the bearings. The old front bearing popped right out. The rear bearing I heated the engine to 220, and it just fell out. Then the fun began! I worked on the front bearing first, and I noticed right off that the new one was tighter fit. I heated the engine up to 230 or so, got it in. Cool. Then I worked on the rear. No dice. Took it up to 250. Nope. Then 290. Nope. Not even close! I set the new bearing on top of the old, and in a "you've GOT to be kidding me" moment, saw that the new one appeared to be .5mm larger! Well that was never going to fit for sure. I wasn't about to give up though, so out came the dremel, and I started working on the outer race of the new bearing, slowly grinding it, taking great care to make sure it stayed evenly trimmed. Two hours(!) later, I was able to get it to go in with a little mild heating of the block (hoping I didn't take too much off and have it be loose). Looks like it was about perfect, as to get it in fully I had to whack the crank pretty good with a rubber mallet.
The new ceramic bearings were a HUGE difference. When spinning the crank with my fingers it spun very freely compared to the originals. My entire drivetrain is now fully ceramic bearings, and it shows.
I let the crank cure overnight, and after 24 hours of curing, took it outside to fire up. I fully expected some tuning changes, and it was as you'd expect, on the rich side. Few tweaks of the needle, and right away it was very noticeably very, very quick to spool. I will get a chance to fully test at next weekend's final TNT before we begin our cash days events.
